sdrplay_dump1090 and KERNEL32.DLL
EA3HUF
Postby EA3HUF » Sat Aug 19, 2017 8:08 am
I am trying to use sdrplay_dump90 in windows XP with an RSP2.
If I execute dump1090 I get a windows warning:
sdrplay_dump1090.exe - Entry point not found.
The procedure entry point CancelSynchronousIo could not be located in the dynamic link library KERNEL32.dll
I searched the web and I found that this warning could appear when an application does not support windowsXP. However I have not seen any specification or release note specifying dump1090 not supporting winXP. As I had the original dump1090_sdrplay.exe (vs 1.10.2910.14) working with an RSP1 on that same computer perfectly I supposed the new dump1090 also should work
How I could fix the problem ?
In case sdrplay_dump1090 does not support winXP is there any earlier version I could use with an RSP2 ? Any workaround ?
