Hi Andy! (and everyone else)
more interesting ideas, thanks
![Smile :)](./images/smilies/icon_e_smile.gif)
I have just been a eBaying and spent my savings on a used Wellbrook Communications LFL1010
here's hoping
the plan is, to rotate it so the null is pointing at the local TX (yes, apparently the mast can be seen from my house LOL)
and hope that will reduce the LF issues (and some of the noise) screening and earthing seem to be key?
I will probably use the discone with a high pass filter so the FM band and above will be accessible probably looking to source a HPF that gives cutoff at about 5MHz
this is unlikely to be the most sensitive arrangement, but I "think" it will be workable.
why oh why are people being herded into smaller and smaller houses, in more and more densely populated areas?
I have enough issues with WIFI LOL
(there is a "Local" 100w BT WiFi link, and, due to population density I can detect 30+ local wifi networks :O
I wish I lived out the way more lol
anyhow... thanks for all the help guys (no Gals spotted)
oh did I mention there are a lot of Sky customers locally using ethernet over mains adapters too?
I will let you all know how the LFL1010 works out
there is no coupler with it, but I imagine that is just the usual choke capacitor arrangement
I suppose, a little background might be useful here..
I am (was?) a qualified elecrtonics engineer, until I stopped soldering because I was repeatedly burning my nose with the iron LOL
these days, I work in IT with a HUGE screen and, prepare for a future where my sight gets even worse (hence my interest in home automation)
back in the day I would have built my own loop using a 6SN7GT or something
(I still believe valves are superior front end devices, especially at MF)
but these days home construction gets delegated to my long suffering friends
I do fix their PCs (and try to convert them to Linux) in return mind
again, thanks everyone!
Gazzzman
