AM Broadcast Band is Quiet
Alan1
Postby Alan1 » Fri Oct 21, 2016 3:47 am
I am not seeing/hearing anything on the AM broadcast band. Wondering, what is the trick? I am able to hear the FM broadcast, a slight WWV signal on 15MHz, just not AM. Any help is appreciated. I am using a 100ft long wire with an an antenna tuner.
Thank you,
Alan
Misterj
Re: AM Broadcast Band is Quiet
Postby Misterj » Fri Oct 21, 2016 3:54 pm
Alan1, I can tune several local AM stations for 590 - 1490 kHz. I am not good at getting the best audio and I am using just a short, about 12 cm, vertical inside. I think the best idea is for you to post screenshots of your Main and RX Control windows so others can make suggestions. Enjoy, John.
Alan1
Postby Alan1 » Mon Oct 24, 2016 12:18 pm
Hi John,
Thanks for the reply! Since away currently, I am not able to get a screenshot. Based on your response though, it does not sound like a single setting causing it. When back, I will look again at the system and see what I can find. If nothing, I will send the screenshot. Thanks again for the response.
Alan
NN4F
Postby NN4F » Mon Oct 24, 2016 9:15 pm
Alan1 wrote:Hi,
Thank you,
Alan
Alan,
It could be your tuner blocking the signals, try AM without your tuner, my 160m dipole can be deaf on AM when tuned for a higher band...
Just give it a quick try without the tuner inline...
Paul - NN4F
