Sdrplay & Ant500
Scooby300
Sdrplay & Ant500
Postby Scooby300 » Sun Aug 02, 2015 10:33 am
Hi would this combination work
Re: Sdrplay & Ant500
Postby Tech_Support » Sun Aug 02, 2015 11:05 am
We have no direct experience of this antenna, but on the face of it, it should be suitable for use with the RSP between VHF and upper end of UHF.
Perhaps there is someone out there with direct experience......?
Sasan
Postby Sasan » Sun Aug 02, 2015 1:14 pm
Hi
Yes, ANT500 works perfectly with SDRPlay
I've tested it with FM (88-108MHZ) and some parts of VHF-UHF (120-600MHZ) with good results.
(Its frequency support is advertised as 75-1000MHZ and I haven't tested it with more than 600MHZ)
DF2HF, NM9A, EP2C
Scooby300
Postby Scooby300 » Sun Aug 02, 2015 4:29 pm
Hi Sasan
Thanks for that does it give much range or is it just for local
Sasan
Postby Sasan » Sun Aug 02, 2015 5:43 pm
Well, that depends on your definition of 'local' ;)
I've tuned to local FM stations, local police radio, airport's ATIS, airband (communication between pilots and control tower), etc
So, that's a very good general purpose antenna to get you started.
Of course, you'll need specific antennas for specific tasks (HF reception, NOAA weather satellite reception, etc)
As you get more experienced, you'll build/buy antennas for your needs, but don't worry about that now
DF2HF, NM9A, EP2C
Users browsing this forum: glovisol and 9 guests
