pov: "overflow" error
oz6og
Postby oz6og » Wed Jan 18, 2017 9:48 am
I am getting this message every time I start up my RSP2, what can be wrong?
hfsdpk11
Re: pov: "overflow" error
Postby hfsdpk11 » Fri May 05, 2017 3:47 pm
I've had the pov overflow come up a couple of times which I think was due to over-aggressive parameter changing on my part. In each case, SDRUno re-started ok. It may be that you set up a scenario that SDRUno just doesn't like and will throw the pov overflow when it attempts to start up with that "nasty" parameters set. I'd suggest that you un-install SDRUno and re-install it in an attempt to clear out any stored values in files that aren't immediately obvious to us general users.
Postby Tech_Support » Fri May 05, 2017 4:26 pm
Uninstalling and re-installing SDRuno will not help. You need to reset the registry settings in SDRuno. This can be done from within SDRuno with the latest version of the software. Please note that you will lose all stored settings if you do this.
