Yes, I am doing exactly so.
The only differences I could see are:
- I am on a raspi3 by SSH, on the same computer where I open the map. But this should be irrelevant.
- I am working on an updated Raspbian Jessie, not on the sdrplay image.
I installed the API and sdrplay_dump1090 from the sdrplay website some 5 days ago so they are the latest versions.
It works perfect with Virtual Radar with RSP1 and RSP2. I tried both.
Not sure what to say. I could sent a picture of the shell and folders but I think this is not possible on this forum .
Where the json files are written on your system? In which folder ? I can not find them.
Only If I use the option to write the json files in a folder like public_html I can see them, but I do not know where the .js scripts in public_html look for them. In
public_html/script.js there is a function that gets data from
/dump1090/data.jsonCode: Select all
function fetchData() {
$.getJSON('/dump1090/data.json'
but I am not sure where this
dump1090 folder should be.
In any case, when I use the option --write-json, the files I see are
-aircraft.json
-history_##.json
-receiver.json
-stats.json
but no data.json !!!
