Audio cuts in and out
aos_malaga
Re: Audio cuts in and out
Postby aos_malaga » Mon Oct 09, 2017 10:38 am
Good morning.
Using SDRUno I have some audio short clippings, only when BW is 8 or 10 MHz. If set to 7 or less, audio is perfect.
The audio interruptions are every 0,5 sec (approx), no matter mode (FM, SSB, AM), and filter setup doesn't have effect.
Also it is present either there are signal or only noise.
Computer is a newest AMD Ryzen 5 with 16 GB RAM and SSD hard drive.
CPU use is less than 10%.
There are no problems when using HDSDR nor with SDR Console (either 2 or 3).
Any ideas?
Andres.
mark.
Postby mark. » Mon Oct 09, 2017 1:29 pm
Check my post right before yours. Make sure SDRuno and your sound card are both set to the same value. Usually either 48khz or 44.1khz
aos_malaga
Postby aos_malaga » Mon Oct 09, 2017 2:54 pm
Shall do when at home. I know where to search in the sound card, but, where is the option in SDRUno?
Thanks a lot!
mark.
Postby mark. » Tue Oct 10, 2017 1:35 pm
I'm not sure if there is one in SDRuno. I changed it in my sound card first and it solved the problem. So I'm assuming SDRuno default is 44.1khz.
aos_malaga
Postby aos_malaga » Mon Oct 16, 2017 11:29 am
God moringn,
Tested my SDRPlay 2 + SDRUno with all the audio sampling rates from 22Khz up to 96 Khz. Also using the USB 3 ports.
Result: the same. Sampling 8 MHz (or higher) with SDRUno produces audio clipping. 7 Mhz and lower: no problems.
HDSDR, SDRConsole can use 10 Mhz without any problems, using same hardware.
Andres, Ea7FkT.
Postby Mike2459 » Mon Oct 16, 2017 7:52 pm
I have the same problem on my Asus M5A99 motherboard computer with an AMD FX-8320E Eight-core processor @3.5 Ghz Windows 10 X64 and Windows 7 X64 (dual boot)).
I disabled several of the USB ports in the BIOS it helped somewhat. (It now begins to stutter at 4MHZ Decimation 1.)
I tried my SDRPlay RSP2 on a Dell E5400 Laptop (Intel Dual Core 2.53 Ghz CPU, 2GB RAM, Win 7 32bit.)
The SDRPlay runs smoothly at 10Mhz and Decimation 1.
Perplexing.
rzar66
Postby rzar66 » Wed Dec 06, 2017 1:47 am
Also having the same issue with the audio cutting in and out at 7 to 10 bw.
