NEED CHECKLIST FOR SDRPAY RSP2/NOOELEC BALUN 1:9 SETUP
ki5ss
Postby ki5ss » Wed May 03, 2017 2:07 am
After my first attempted to receive signals with SDRPLAY RSP2 with the NooElec Balun 1:9 and did not receive any signals I gave up and set the SDRPLAY RSP2 aside and neglected to give it a second try. That was last year. Now I want to give it a second try. I need a check list for the SDRPLAY RSP2 with the NooElec Balun 1:9 with a BNC adapter for various bands. Does anyone have such a check list?
lauchlin
Re: NEED CHECKLIST FOR SDRPAY RSP2/NOOELEC BALUN 1:9 SETUP
Postby lauchlin » Wed May 03, 2017 12:35 pm
Why use the balun at all .What software are you using
VE7SHM
mikexeno
Postby mikexeno » Wed May 03, 2017 1:30 pm
SDRplay has a guide online along with connections examples.
http://www.sdrplay.com/wp-content/uploa ... uidev2.pdf
ki5ss
Postby ki5ss » Thu May 04, 2017 4:44 am
THANKS! I was double checking my information. I already have the PDF link. So, I am good to go for testing the balun with SDRPLAY RSP2, even if I may not need the balun like the other post implies.
lauchlin
Postby lauchlin » Thu May 04, 2017 8:31 pm
My SDRplay 2 works just fine with out a balun on my 80 meter delta loop works fine on my Wellbrook loop work fine on my vertical i don't use a balun with any of my sdr stuff
VE7SHM
ki5ss
Postby ki5ss » Fri May 05, 2017 7:27 am
The problem was probably more associated with me not advancing enough along the learning curve with SDRuno and SDRPlay RSP2 than with the Nooelec Balun 1:9 setup. Anyway I finally got SDRuno working because I focused on learning more about it by spending lengthy time with it. So much for "plug n play." I noticed later that I did not have the Nooelec Balun connected to the SDRPlay RSP2. So much for trying new options.
Thanks folks! 73
ki5ss
Postby ki5ss » Fri May 05, 2017 7:29 am
The problem was probably more associated with me not advancing enough along the learning curve with SDRuno and SDRPlay RSP2 than with the Nooelec Balun 1:9 setup. Anyway I finally got SDRuno working because I focused on learning more about it by spending lengthy time with it. So much for "plug n play." I noticed later that I did not have the Nooelec Balun connected to the SDRPlay RSP2. A random length wire was connected directly to the SDRPlay RSP2. So much for trying new options.
Thanks folks! 73
