Waterfall saving tool
DVE
Postby DVE » Sat Sep 09, 2017 4:05 pm
Hi all,
I finished a first version of the python application, that saving a waterfall in the file, so its easy to check whats going on the band.
Command line:
python3 wf2img.py --sdr=sdrplay --imagewidth=2048 --sr=8000000 --f=100000000 --average=32 --sdrgain="IFGR:40;RFGR:4"
Result: FM band
Sources and installation manual:
https://github.com/dmitryelj/SDR-Waterfall2Img
Feedback is welcomed.
DVE
Re: Waterfall saving tool
Postby DVE » Sat Oct 28, 2017 8:15 am
Hi all.
Lots of improvements in code: IQ saving, timetable/batch mode, Raspberry Pi support.
URL is the same: https://github.com/dmitryelj/SDR-Waterfall2Img
BackgroundNoise
Postby BackgroundNoise » Fri Nov 30, 2018 4:13 am
Hi DVE,
This utility looks nice. Using python provides a lot of flexibility for the user.
With SDRplay devices, like RSP2pro, you have the option of using Zero IF or Low IF modes.
The switch of modes involves setting an IF bandwidth.
Does your code allow this setting?
You have to be careful when setting the mode so it would also be useful to read back the radio's "state" to check the settings.
I had a look at your code but it wasn't obvious that you could change modes.
Thanks!
Last edited by BackgroundNoise on Thu Jan 01, 1970 12:00 am, edited 0 times in total.
Users browsing this forum: No registered users and 14 guests
