SDR Console v3
bigroo1958
SDR Console v3
Postby bigroo1958 » Sat Jan 06, 2018 1:16 am
Does anyone know when using the playback of a recording can the "Rewind" and "Fast Forward" button time be changed?
At present it will rewind or fast forward only 5 seconds. It would be nice to be able to change this setting at will.
Bobman50
Re: SDR Console v3
Postby Bobman50 » Sat Jan 13, 2018 7:49 pm
Hi, Have you tried to use the Navigator playback window? Here you can set a time forward, for instance +15 minutes or more. This should work as "fast forward". Unfortunately it does not seem to work backwards. Still I also have other problems with the navigator which I will post separately.
bigroo1958
Re: SDR Console v3
Postby bigroo1958 » Sat Jan 13, 2018 9:32 pm
Hi Bobman50,
Yes, this is where the fast forward/rewind buttons are, I would like to be able to set the button from 5 seconds to 2 seconds for replaying a small portion of the recording.
If anyone is familiar with the Total Recorder program, this program has this feature. There is a drop own to select the rewind time to whatever you want. I use this program to record the audio and replay a few seconds to work out what the call letters of a station are if not clear on the main recording.
