RF Measurement [Magnitude(frequency)]
Jim-Alt
Postby Jim-Alt » Mon Mar 26, 2018 12:23 pm
I'm using GRC with a DVB-T tuner Chip.
I would like to know if there is a way to extract the Magnitude and the frequencies from a GT GUI Frequency Sink ?
I have also recorded the signal with a File Sink in order to process the data myself to get the same result but everytime I get something different than the result plot on the QT GUI Frequency Sink.
In the attachments you'll found the recorded signal as a binary file and a Python generated code from GRC corresponding to the display I want to be able either to generate or to extract data from it.
You'll find the code I have develop to process those data below :
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
import matplotlib.pyplot as plt
import numpy as np
import scipy.io
#Variables
sample_rate = 800000.0
FFT_size = 2048
delta_sample = (1.0 / sample_rate)
#print("delta_sample [s]=",delta_sample)
#File Recovery
signal = scipy.fromfile(open("/home/jalibert/Documents/3-GRC/2-Data_Output/Data_Recorded.bin"), dtype=scipy.float32)
#Check the lenght of the sample recorded
length_signal = len(signal)
#Calcul the duration of the sample recorded in [s]
sample_time = length_signal * delta_sample
#Creation of the abscissa axis in a list
t=[]
for index,data in enumerate (signal) :
   time = delta_sample * index
   t.append(time)
#Display Temporal Signal
#Slicing the sample to reduce the duration of the process
t_slice = t[0:FFT_size]
signal_slice = signal[0:FFT_size]
plt.figure()
plt.plot(t_slice,signal_slice)
plt.title('Temporal Signal Sample 1')
plt.ylabel('Amplitude')
#fft process
signal_fft_slice = np.fft.fft(signal_slice)
freq_slice= np.fft.fftfreq(len(signal_fft_slice))
#Amplitude Calculation (Linear)
signal_fft_slice_magnitude_Lin = np.sqrt(np.square(signal_fft_slice.real)+np.square(signal_fft_slice.imag))
#Amplitude Calculation (dB)
signal_fft_slice_magnitude_dB = 10 * np.log10(signal_fft_slice_magnitude_Lin/1000)
plt.figure()
plt.plot(freq_slice,signal_fft_slice_magnitude_Lin)
plt.title('FFT')
plt.ylabel('Amplitude [Lin]')
plt.figure()
plt.plot(freq_slice,signal_fft_slice_magnitude_dB)
plt.title('FFT')
plt.ylabel('Amplitude [dB]')
#Peack Searching
max_mag = -100
index_f_max = 0
for index, mag in enumerate (signal_fft_slice_magnitude_dB):
   if mag > max_mag :
      max_mag = mag
      index_f_mag = index
print("Peak :")
print("Amplitude Lineaire :",signal_fft_slice_magnitude_Lin[index_f_mag])
print("Amplitude : [dB]",max_mag)
print("Frequence : [Hz]",freq_slice[index_f_mag]*sample_rate)
plt.show()
Edit :
I haven't been able to attach the files I wanted to, due to the format.
If you need this file, I'll gladly send them to your email.
Any help will be really appreciated.
Cordially
J.Alt
Re: RF Measurement [Magnitude(frequency)]
Postby sdrplay » Mon Mar 26, 2018 2:56 pm
I have moved this thread from the SDRplay Related forum, as it's not SDRplay related. Please also note that this is not a help group for Gnu Radio, you may get more specific responses from the Gnu Radio forums.
