RSP2A and RPi 3 B+
Re: RSP2A and RPi 3 B+
I appreciate your situation and efforts it was not a slight.
Spent all day yesterday looking at this [censored] thing - no luck wifi is just not there!
RSP2 and RPi 3 B+
I am thinking about getting a Raspberry Pi 3 B+. (Already have the rpi 2).
A couple of quick questions.....
How many virtual receivers will the RSP3 B+ handle?
Is the 1.5 Gig better than the 1.2 gig setup?
Is it possible to sync/control a transceiver that is running CAT software on an adjacent Windows 10 computer?
(The windows computer will be running HRD, CWSkimmer, WSJT-x etc.)
John
KW7A
John
KW7A
I have something to ask about the RasPi-image:
1) Is it based and compatible with some well-known distro? Raspbian I hope?
2) Is there included a thing which allows one to receive USB by using command line interface?
73, Jukka
73, Jukka
Hi all.
I tested the last OS image from SDRPlay Team, WSJT-X from https://physics.princeton.edu/pulsar/k1jt/wsjtx.html and ALSA virtual audio cable - it works, WSPR messages can be autonomously decoded.
So, it makes sense to add WSJT-X and alsa init command to the OS image.
- RaspberryPi_WSPR.jpg (183.16 KiB) Viewed 15875 times
