CubicSDR-0.2.3-x86_64.AppImag
daniel.aronovitch
Postby daniel.aronovitch » Wed May 23, 2018 3:00 pm
When I try to launch the CubicSDR-0.2.3 image provided, I get that message:
/lib/x86_64-linux-gnu/libthai.so.0: version `LIBTHAI_0.1.25' not found (required by /usr/lib64/libpango-1.0.so.0)
but, when I do a
ldd /usr/lib64/libpango-1.0.so.0
linux-vdso.so.1 (0x00007ffc10153000)
libgobject-2.0.so.0 => /usr/lib64/libgobject-2.0.so.0 (0x00007fbb70ddc000)
libglib-2.0.so.0 => /usr/lib64/libglib-2.0.so.0 (0x00007fbb70ac4000)
libm.so.6 => /lib64/libm.so.6 (0x00007fbb70731000)
libthai.so.0 => /usr/local/lib64/libthai.so.0 (0x00007fbb70527000)
libfribidi.so.0 => /usr/lib64/libfribidi.so.0 (0x00007fbb7030b000)
libc.so.6 => /lib64/libc.so.6 (0x00007fbb6ff4d000)
libffi.so.7 => /usr/lib64/libffi.so.7 (0x00007fbb6fd43000)
libpcre.so.1 => /usr/lib64/libpcre.so.1 (0x00007fbb6fab6000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00007fbb6f897000)
/lib64/ld-linux-x86-64.so.2 (0x00007fbb71277000)
libdatrie.so.1 => /usr/lib64/libdatrie.so.1 (0x00007fbb6f68f000)
as you can see, libpango find libthai.
Any suggestions ?
DA
Last edited by daniel.aronovitch on Thu Jan 01, 1970 12:00 am, edited 0 times in total.
Re: CubicSDR-0.2.3-x86_64.AppImag
Postby sdrplay » Wed May 23, 2018 3:11 pm
The best place to ask about CubicSDR issues is here:
https://github.com/cjcliffe/CubicSDR/issues
inchcombec
Postby inchcombec » Tue Jun 12, 2018 6:19 pm
Try downloading the source code from here:
https://github.com/cjcliffe/CubicSDR/releases/tag/0.2.3
Then follow these install instructions:
cd CubicSDR
mkdir build
cd build
cmake ../ -DCMAKE_BUILD_TYPE=Release \
-DwxWidgets_CONFIG_EXECUTABLE=~/Dev/wxWidgets-staticlib/bin/wx-config
make
sudo make install
This worked for fixing it for me on an install of Linux Mint 18.3. Apparently the new CubicSDR versions don't play nice for some reason. Hope this helps.
**EDIT. If the cmake fails it might be because it assumes all is installed in /Dev. Point that last part to where you actually put wx-config. If you followed the standard instructions https://www.sdrplay.com/docs/SDRplay_no ... s_Flow.pdf that it is in /Dev.
Users browsing this forum: nOtko and 10 guests
