CW decode software
BCORover
CW decode software
Postby BCORover » Wed Oct 21, 2015 11:23 am
I have just ordered my SDR Play and was wondering if any of the available software packages (currently looking at SDRConsole) have inbuilt CW decode capability - or a plugin that would do so ?
John
NN4F
Re: CW decode software
Postby NN4F » Wed Oct 21, 2015 2:45 pm
John,
there are several programs you can use to decode cw, CWget, FLDigi, Multipsk, I personally have found CWGet the most accurate on machine/keyer CW, can get a bit lost on straight key morse...
you can run any sdr program and pipe the audio to the decoder, via a virtual cable, or if you look in your sound card recording devices, you can use stereo mix too...
Older SDR console used to have a CW decoder, but the author took it out, now only does PSK/RTTY, lots of people on his yahoo group have been asking for the CW back, so who knows...
Paul - NN4F
BCORover
Postby BCORover » Wed Oct 21, 2015 4:49 pm
Hello Paul
I really appreciate your reply, and will look through the programs you mention.
Could you clarify one point for me? What is a "virtual cable"?
Thank you for your help.
John
Alastair_BKA
Postby Alastair_BKA » Thu Oct 22, 2015 12:37 am
BCORover wrote:Hello Paul
John
http://vb-audio.pagesperso-orange.fr/Cable/
Last edited by Alastair_BKA on Thu Jan 01, 1970 12:00 am, edited 0 times in total.
kx7m
Postby kx7m » Sun Nov 08, 2015 10:46 pm
I guess the same applies to CW Skimmer, i.e. the only way to get SDRPlay to "talk" to skimmer is via Virtual Audio Cable, limiting the deciding bandwidth to 24kHz.
Has anyone played with CWSkimmer and SDRPlay?
Fones
Postby Fones » Tue Nov 10, 2015 11:36 am
I did it a while ago, using VAC.
NN4F
Postby NN4F » Fri Nov 13, 2015 3:49 pm
kx7m wrote:I guess the same applies to CW Skimmer, i.e. the only way to get SDRPlay to "talk" to skimmer is via Virtual Audio Cable, limiting the deciding bandwidth to 24kHz.
You can set VAC to 192khz wide and and use softrock IF, works great, and using sdr-console you can have multiple VFO's feedinfg separate VAC's
Postby jon » Sat Feb 13, 2016 12:09 pm
There's a neat video on setting up CW Skimmer and HDSDR here https://youtu.be/tw205yjZsug
