HDSDR sample rate not working
ugallu
Postby ugallu » Mon Jun 11, 2018 5:35 am
When I change the sample rate in the device controller, it does not work for anything other than 2 MHz.
It doesn't matter what setting I choose, only 2 MHz of bandwidth are displayed on the screen.
In the screenshots below, both HDSDR and SDRuno are running at 10 MHz sample rate, but HDSDR only shows 2 MHz.
Image Image
Does anybody know why this is happening? What settings am I messing up?
Re: HDSDR sample rate not working
Postby sdrplay » Mon Jun 11, 2018 5:39 am
The sample rate is 10 MHz, but the IF bandwidth is only 1.536 MHz - if you change that to 8 MHz, then you will see the full spectrum width.
ugallu
Postby ugallu » Mon Jun 11, 2018 5:46 am
sdrplay wrote:The sample rate is 10 MHz, but the IF bandwidth is only 1.536 MHz - if you change that to 8 MHz, then you will see the full spectrum width.
That fixed my problem. Thanks a lot. :D
