SDRplay_SDRuno Ver. 1.23.1 HAS BIG PROBLEMS PERHAPS...!!
Postby glovisol » Mon Jul 09, 2018 6:47 pm
Today I downloaded Ver. 1.23.1.
I de-installed Ver. 1.23 first, then installed the new version. I found severe intermodulation on all bands and at all settings. There must be severe problems there.....
Before re-installing Ver 1.23, I re-installed Ver. 1.22 (even though I operate an RSPduo). I may be wrong, but noise performance with Ver. 1.22 on the 20 m band seems far superior.....Perhaps a second opinion should be in order.
Re: SDRplay_SDRuno Ver. 1.23.1 HAS BIG PROBLEMS PERHAPS...!!
Postby Tech_Support » Mon Jul 09, 2018 8:55 pm
Hello glovisol,
The only change between 1.23 and 1.23.1 is a change to the API to correct a bug that was affecting the RSPduo tuner 2 at a 10 MHz sampling rate. Nothing else has changed.
Can you confirm what hardware you are using and post screen shots that show the effects you are seeing? Ideally open up a support ticket so that we don't miss you posts.
Postby glovisol » Tue Jul 10, 2018 12:38 pm
Hello Tech. Support,
Today I tried to investigate the problem as per your instructions. I de-installed Ver. 1.23 and re-installed Ver. 1.23.1. SDRuno installed smoothly and I tested it all morning without any problem. I cannot explain what happened yesterday when for half an hour it was mis-behaving and showing such a level of intermod I could not read the received SSB signals, compelling me to go re-install Ver. 1.23. The only explanation could be that something went wrong during installation.
Anyway all O.K. now, Ver. 1.23.1 installed again & working and apologies for a false alarm!
Kind regards,
PC: Lenovo X61 laptop
O.S.: Windows 7 Professional /32 Bit
Processor: Intel Core 2 Duo, CPU T 7300@ 2 GHz
RAM: 3 GB
