Why 24mhz Reference
N2LEE
Why 24mhz Reference
Postby N2LEE » Mon Jul 30, 2018 12:17 am
I am certainly no expert in this area but all of my test equipment uses 10mhz references. Also both of my GPSDO references are 10mhz.
Why did SDRPlay select 24mhz for a reference frequency ?
Lee
Re: Why 24mhz Reference
Postby Tech_Support » Mon Jul 30, 2018 5:37 am
Hello Lee,
The chipset within the RSP range of products requires a 24 MHz reference clock. The Leo Bodnar GPSDO is capable of delivering a 24 MHz output.
SDRnerd
Postby SDRnerd » Mon Jul 30, 2018 12:07 pm
As this thread is already open, I have a few questions about this.
Which Leo Bodnar model is best suited as there are 2 types on sale? Secondly, can the output from these devices be directly connected to the SDRplay or is there need for some attenuation or wave transformation (square to pure sinewave). I have some interrest but do not want to destroy my SDRduo with a wrong input signal.
Best 73"
Ron Liekens
N2LEE
Postby N2LEE » Mon Jul 30, 2018 6:56 pm
Leo's unit is the first one that came to my mind as well because it is the only one I know that has a variable output.
Lee
Postby Tech_Support » Mon Jul 30, 2018 9:16 pm
SDRnerd wrote:As this thread is already open, I have a few questions about this.
Best 73"
Ron Liekens
Hello Ron,
With the RSPduo, you can direct connect to the Leo Bodnar GPSDO without any kind of interface circuit. We recommend the dual output version as it allows the use of a separate 10 MHz output for use with general instruments which as has already been remarked upon typically use a 10 MHz clock. Either device should work fine, but we have tested our units with the device with the dual outputs.
SDRnerd
Postby SDRnerd » Sun Aug 12, 2018 11:03 am
Thanks for the exact and detailed info.
testpoint
Postby testpoint » Fri Nov 09, 2018 7:28 am
GPSDO for 24MHz also is easy to get, please check the following GPSDO we designed, about 150 USD, include 10MHz and 24MHz output, with LCD screen:
rear
face
Postby Tech_Support » Fri Nov 09, 2018 11:37 am
Hello Testpoint,
Is this device commercially available?
Users browsing this forum: No registered users and 17 guests
