sdrplay rsp1a recording
Hi all im trying to record on sdruno on my sdrplay rsp1a,its saying its recording but there is no audio on playback.am I missing something?
regards paul
regards paul
Re: sdrplay rsp1a recording
SDRuno records the entire bandwidth of the IQ spectrum being received centered around the LO frequency. When you are playing that back in SDRuno, you can then select the VFO you want to listen to.
If you have done that, check that the audio output device in the VRX Control Panel is correct.
