UNO v 1.23.1 strange behaviour
KE2KB
Postby KE2KB » Mon Aug 06, 2018 2:44 pm
Hi;
I have an RSP1.
I just un-installed SDRUNO ver 1.21 (even cleaned out the registry, then rebooted), and installed version 1.23.1.
I set up ver 1.23.1 the same as I had ver 1.21 set up:
Input:
Input Level Display: Gain
IF Mode: Low-IF
SR (Mhz): 2.0
Dec: 2
LO Lock: Off
AGC: Off
LNA: Off
Mode: LSB
Freq: 7.140.000
I left all of the other settings at default.
Note: When I first installed ver 1.23.1, the LNA was ON and AGC was ON.
The first thing I noticed is that I was seeing and hearing lots of broadcast AM stations on the 40m ham band. When I changed from Zero-IF to Low-IF that reduced the broadcast chatter.
Second thing I found was that the LNA button was acting in reverse as I would expect. When it was lit up (white), the spectrum display appeared as though the LNA was off, and when I clicked the button to turn LNA off (dark), the spectrum looked like it would when LNA is on.
Next, I noticed that the IF gain slider was not working properly. It was impossible to move it to the setting I desired - this was with AGC off.
The movement of the slider, and other controls appeared sluggish; as though another process was eating most of CPU resources. But there was nothing else running on the PC.
System specs:
MSI P67 with Intel i5 2500 @ 3.4Ghz
16GB DDR3 RAM
NVidia GeForce 750 GTX 2GB
OS: Windows 7 Ultimate SP1 (up-to-date)
OS drive: 512GB (partitioned into 2 250GB) SSD (Samsung 850 EVO)
Not being content with the newer version (1.23.1), I completely un-installed it, and re-installed ver 1.21.
After setting it up as it was before, it seemed to be working fine.
Next, I re-installed ver 1.23.1 alongside ver 1.21, with each version in a separate folder.
Now, when I run either version they seem to perform the same. No problems with ver 1.23.1.
I am sure that I am actually running the version I want to run by starting the program from its install folder.
So, what happened?
Thanks for your help
KE2KB
Re: UNO v 1.23.1 strange behaviour
Postby sdrplay » Mon Aug 06, 2018 2:51 pm
RSP1 gain control is broken in SDRuno 1.23 - I wouldn't recommend using 1.23 with RSP1. RSP1A/RSP2/RSP2pro/RSPduo are ok as they use a different gain control.
Roger
Postby Roger » Mon Aug 06, 2018 8:20 pm
Why use SDRuno 1.21? The latest version for RSP1 is 1.22.
