Problem running RPI ADSB V1.3 - Help pse!
navzptc
Postby navzptc » Sat Aug 18, 2018 10:36 am
I have downloaded and managed to unpack the RPI ADS-B version 1.3 package (I think!!), but ran into an error whilst trying to run the package by ./dump1090 - presume this is the correct command!
Following error came up:-
./dump1090: error while loading shared libraries: libmirsdrapi-rsp.so.2.11: cannot open shared object file: No such file or directory
Using a RPI3 running raspbian stretch light, dated June 2018 (latest version).
Any help, pointers etc very much appreciated.
navzptc
Re: Problem running RPI ADSB V1.3 - Sorted!!
Postby navzptc » Tue Aug 21, 2018 12:34 pm
Finally managed to get this to run :D
Started from ver. 0.1 and worked my way up to the latest 1.3, but copied relevant files from /usr/local/lib to the usr/lib after each setup, and now no problem with the error message.
Using ./dump1090 --dev-sdrplay --quiet --net --oversample which seems to be working quite well.
Will be interesting to see how it compares with my normal RTL setup when my splitter arrives :)
swwifty
Re: Problem running RPI ADSB V1.3 - Help pse!
Postby swwifty » Mon Oct 08, 2018 10:28 pm
Can you please explain in greater detail what you did to fix this problem? I'm running to the exact same situation with a PI 3, and Raspbian.
I'm kind of surprised this package is listed for download on the sdrplay site, but has no documentation, and clearly doesn't work.
I can't figure out for the life of me which version of librtlsdr0 contains this libmirsdrapi-rsp.so.2.11 version of the library?
