Using 2 RSP2 receivers
johnhlong
Postby johnhlong » Mon Sep 10, 2018 3:10 am
Is there a way to sync 2 RSP2 receivers like you can when using a RSP-Duo and the "RSYN1 button?
OR
If I have 2 RSP2s using two separate instances of SDRUno (on the same computer).
What is the best way to transfer transmission control between the 2 RSP2's to change which SDRuno instance controls (or sync) a single shared transmitter.
Freesher
Re: Using 2 RSP2 receivers
Postby Freesher » Tue Sep 11, 2018 7:20 pm
Yes, Though I know the process will require a lot of tweaking.
