Wellbrook ALA1530LN
Wellbrook ALA1530LN
Postby Paul » Tue Sep 18, 2018 9:16 am
I have been really pleased with this antenna.
However, I now have an issue - Worked normaly yesterday morning, but on restartinng in late evening, whilst the antenna still worked the and power light on the interface was on, it's performance had deterioerated to "only just" receiving.
Comparison with my other antennas confirmed that the RSP2 was working fine on this Port (A) and that the Hi-Z was also working normaly.
On further investigation, I find that removing the power source has no effect on it's performance.
Before investigating further, if the power led is on, is it still possible for this fault to be it's inbuilt fuse?
If not, how deep is the doo-doo that I'm possibly in?
Technical knowledge and expertise - zero.
Any suggestions welcomed.
Re: Wellbrook ALA1530LN
Postby Paul » Tue Sep 18, 2018 4:36 pm
Addendum to my previous post:
Having gone out, inspected the conections and cable for any visible fault (water ingress highly unlikey and connections made meticulously), came back in, plugged in power and hey presto - back to normal.
However, an unexplained aberration is a concern.
Postby Mike2459 » Wed Sep 19, 2018 9:44 am
Paul: What is the procedure for resetting the built-in fuse? Or, does it require replacement if it trips?
Postby Paul » Wed Sep 19, 2018 10:35 am
Hi Mike
I thought that it was replacement, but I'll check asap.
Postby Paul » Wed Sep 19, 2018 10:58 am
It's replacable Mike
Postby Mike2459 » Wed Sep 19, 2018 12:33 pm
Thanks Paul
I thought perhaps it was an electronic fuse. I have one of these on a supply for a Mini Whip. In order to reset it after an overload, I must power it down and turn it back on.
