Bandwidt above 1 Mhz won't work
PA0PZD
Postby PA0PZD » Mon Oct 01, 2018 2:18 pm
I just installed the spectrum analyzer SAS on my PC. The bandwidth from 1 Mhz till 10 Mhz is fine working. But above 500 Kc is not. 100 Khz becomes still 1 Mhz. Or the program is crashing. What to do? Or is it because it is an A version? Like to do measurment to MF receiver stages.
Regards Peter PA0PZD
PA0PZD
Re: Bandwidt above 1 Mhz won't work
Postby PA0PZD » Thu Oct 04, 2018 4:40 pm
I read that this is happening, because the sweep buttons below 1 mhz are disabled because of software problemes? Hope that in next comming releases this has been solved.
Peter PA0PZD
SteveAndrew
Postby SteveAndrew » Sat Oct 06, 2018 6:09 am
PA0PZD wrote:The bandwidth from 1 Mhz till 10 Mhz is fine working. But above 500 Kc is not. 100 Khz becomes still 1 Mhz. Or the program is crashing.
Try changing your region setting to something like US or UK. There is a bug where computers set to regions where the ',' is used as a decimal separator. Full sweeps from 1KHZ to 2GHz are already fixed for the next release.
DJ0HF
Postby DJ0HF » Sat Oct 13, 2018 2:05 pm
I found in windows 10 I didn't need to change the region but just go into the region settings and simply change the decimal seperator to a '.' and you can keep the region unchanged.
SteveAndrew
Postby SteveAndrew » Sun Oct 14, 2018 1:18 am
DJ0HF wrote:I found in windows 10 I didn't need to change the region but just go into the region settings and simply change the decimal seperator to a '.' and you can keep the region unchanged.
Thank you for that. The bug has been fixed by forcing the application to use "en-US" culture settings when it's launched, this action doesn't affect any other applications. I've tried setting my own PC to various regions and the fix seems to work.
Return to “Spectrum Analysis”
Users browsing this forum: Google [Bot] and 3 guests
