CubicSDR bookmark Function..save the label
NeilP
Postby NeilP » Fri Nov 02, 2018 7:15 pm
search has not found anything on this topic so . I'll post a question
Cubic SDR...any one use it here?
It aha Book mark function and Label Box so you can save a name to a Frequency
Only I cannot work our how to actually Save the name.
You type the Name you want in the label box...but then mwah ..Hitting enter does thing..There des not seem to be a way to actually Save the Label to anything .
kd1jg
Re: CubicSDR bookmark Function..save the label
Postby kd1jg » Sat Feb 09, 2019 6:39 pm
It appears to be broken in the latest releases.
I found a posting that said to save the bookmark and edit the xml file
where <user_label></user_label> is located
I found that I needed to enter the ascii codes to get the actual text to work
Good luck
