Need new silly green connector for the Hi-Z
wireman
Post by wireman » Tue Nov 06, 2018 1:09 pm
Its taking all my strength to not take a club hammer to the rsp2pro green connector that will not stop in anymore, I knew this would happen when i bought the thing new, i just knew it, its so annoying, they should supply a bag full of em when you buy the thing for a months disposable income, my question is what are the these daft little pieces of plastic called and how many do i get for quid from china
Re: Need new silly green connector for the Hi-Z
Post by Mike2459 » Tue Nov 06, 2018 3:36 pm
CTB9208/3 - Pluggable Terminal Block, 5.08 mm, 3 Ways, 30 AWG, 12 AWG, 2.5 mm², Screw
https://uk.farnell.com/camdenboss/ctb92 ... dp/1717011
Incidentally, there's a price break @50++
Post by g1hbe » Tue Nov 06, 2018 6:12 pm
Can't say I've had any trouble with it, Wireman. Do you plug/unplug it a lot?
wireman
Post by wireman » Fri Nov 23, 2018 7:06 pm
Oh thanks, that's very reasonable, i will get several so can leave them connected to a few experimental antennas, I have fixed mine also, just a little adjustment with a fine screw driver did it, I did used to carry it around a lot stuffed into bag with the connector still on knocking around with other bits so that was probably it, Bought an rsp1a this afternoon also, these really are great clean accurate sdr's and sdruno now my favorite software, very easy on the eye and nice layout
