Bias-t voltage
PD1ET
Bias-t voltage
Postby PD1ET » Fri Nov 09, 2018 10:24 am
The bias-T supplies a voltage of some 5v to connected equipment. I mainly use a mini-whip antenna and that does not work at 5v -not properly anyway. A voltage of 9 to 12 v would be more usefull...
DanubeBCL
Re: Bias-t voltage
Postby DanubeBCL » Fri Nov 09, 2018 4:33 pm
PD1ET wrote:A voltage of 9 to 12 v would be more usefull...
And certainly more difficult and costly to be generated from a 5 V USB voltage.
73, Heinrich
SDRnerd
Re: Bias-t voltage
Postby SDRnerd » Wed Nov 14, 2018 12:03 pm
There are miniwhip designs with low voltage operation. Beware that the current limit is only 45 mA on the bias-T!
73' Ron
Re: Bias-t voltage
Postby g1hbe » Wed Nov 14, 2018 12:34 pm
Ron, isn't the max current 100mA?
Re: Bias-t voltage
Postby Tech_Support » Wed Nov 14, 2018 3:51 pm
Hello folks,
Yes it is 100mA.
vk3alb
Re: Bias-t voltage
Postby vk3alb » Wed Nov 14, 2018 8:22 pm
I think the reason for the 5V bias voltage is understandable.
As someone mentioned there are lower voltage circuits of the mini-whip https://www.g8jnj.net/activeantennas.htm
Lou
VK3ALB
