telive for SDRPlay
deadite66
telive for SDRPlay
Postby deadite66 » Fri Jan 04, 2019 5:43 pm
So i saw on radioreference sdrplay gave sq5bpf an rsp1a in march last year so sdrplay could be supported on telive but did anything come of that?
checked the commits and didn't see anything related.
tried modifying one of the simple grc files but the waveform comes out distorted like sometimes see on gqrx.
RSP2 Pro and RSP1A owner.
deadite66
Re: telive for SDRPlay
Postby deadite66 » Sun Jan 06, 2019 9:28 am
update.
got it working by adding gr-sdrplay and the appropriate source block then messing with the bandwidth and gain.
sq5bpf
Postby sq5bpf » Thu Jan 17, 2019 7:02 pm
I've added a simple 1-channel flowgraph for the RSP-1A to telive. It's in the gnuradio-companion/sdrplay directory. It uses gr_sdrplay.
Update telive, or get it from here:
https://github.com/sq5bpf/telive/tree/m ... on/sdrplay
More receiver flowgraphs and documentation will be added later.
While you're at it, find a weak signal, and compare the rtl-sdr to a sdrplay receiver, both at 2Msps sample rates. There is a great difference!
deadite66
Postby deadite66 » Thu Jan 17, 2019 8:37 pm
many thanks, it appears to be working.
will have to wait until tomorrow morning to listen to them broadcast but the channel data is coming through.
