Updated version of the RSP TCP Server
Postby sdrplay » Sun Feb 17, 2019 11:49 pm
This is a release of an updated version of the RSP TCP Server.
This software is based on a fork of F4FHH’s version of RTL TCP Server. It has been updated to support the RSP features, but also contains an extended mode. The extended mode allows the client (via a compatible interface) to fully control all aspects of the RSPs, including notch filters, Bias-T enable and switching ports (where applicable)
The user guide for the server software can be found on our downloads page and also here: https://www.sdrplay.com/docs/SDRplay_RS ... _Guide.pdf
We have provided binaries for Windows, Mac and RPi on our downloads page and the source code for all platforms can be found on our GitHub repository: https://github.com/SDRplay/RSPTCPServer
To utilise the extended mode, extra commands need to be sent from the client. We have provided an example of this in the form of an ExtIO plugin. You can find the Windows dll on our downloads page and the source code for the plugin on our GitHub repository: https://github.com/SDRplay/ExtIO_RSP_TCP
When the client software uses the ExtIO plugin, the full resolution of the RSP will be accessible remotely (up to 14bits).
In standard mode, the server will be compatible with any RTL server client.
We have also added the server to the RPi 3 image - see viewtopic.php?f=6&t=4135
Return to “SDRplay News”
