SDRuno V1.31 Release
Postby sdrplay » Tue Apr 09, 2019 1:21 pm
We are pleased to announce the release of v1.31 of SDRuno. This release contains a number of bug fixes, functional enhancements and other changes. Since the release of v1.3 of SDRuno, we are aware of a number of users who have had problems with the service API crashing. The root cause of these problems is quite complex, but is PC hardware dependent. We have updated the method by which the service API communicates with various applications and we believe that this will substantially alleviate, if not completely cure the problems that some people have been experiencing. As well as bug fixes, we have made some functional enhancements. Most notably, we have added some new features to the Frequency scanner and made it a simply 1 click operation to switch between Zero IF and Low IF mode and vice-versa.
A full list of changes can be found in the release notes, which are available here: https://www.sdrplay.com/docs/SDRplay_SD ... _Notes.pdf
We strongly recommend that people read these notes carefully as they will help avoid confusion for those people already used to previous versions of SDRuno. It should NOT be necessary to perform a reset or remove your old SDRuno.ini file and so all previous settings from release 1.3 should be preserved.
For anyone who experiences problems or difficulties, we recommend that you open up a support ticket at https://www.sdrplay.com/support
For other comments and feedback, please simply email us at feedback@sdrplay.com. Please note that we do not usually respond to emails sent to feedback unless we have questions, but any observations are always noted.
Return to “SDRplay News”
