ZADIG driver installation
Postby Paul » Fri May 10, 2019 7:29 pm
At the moment, I am setting up a new laptop running Win10 Pro.
So far, I have installed and run both an RSPduo and RSP2. Both have run alone or together optimally.
Would loading the ZADIG driver to add a RTL device cause problems to this installation?
I'm definitely out of my comfort zone on this....
deadite66
Re: ZADIG driver installation
Postby deadite66 » Fri May 10, 2019 8:13 pm
nope, it shouldn't cause any problems.
have rtl-sdr and sdrplay drivers both working fine.
RSP2 Pro and RSP1A owner.
Postby Paul » Fri May 10, 2019 8:29 pm
TVM for your response.My reason for asking was that on my previous laptop I had issues with using my RSPduo and RSP2 together under V1.31.
Although the duo worked perfectly, I could only run the RSP2 in ZIF mode.
At the time I was using a RTL device with ZADIG driver installed.
At the moment I have not loaded the ZADIG driver and will wait any further responses.
Thanks again
mikexeno
Postby mikexeno » Sun May 12, 2019 12:32 am
I strongly advise that you unplug the RSP while installing the ZADIG driver for the RTL. If you bind the ZADIG driver to the RSP by mistake, it's a headache and a half to undo.
Postby Paul » Tue May 14, 2019 7:03 am
Just a thank you again Mike. Your post reference loading ZADIG with only RTL attached was really helpful.
Currently running the RSP2, Duo and RTL together without issues.
Users browsing this forum: sdrom33 and 9 guests
