Raspberry Pi 2 + SDRplay: Setup Guide?
SoulFinderLLC
Postby SoulFinderLLC » Wed Apr 06, 2016 6:18 am
Greetings! I am currently in charge of trying to get our SDRplay working on the Raspberry Pi 2 (model B V1.1). The device specific documentation at http://sdrplay.com/raspberrypi2.html leaves much to be desired, as it simply states "None at this time - the Linux documentation may get you some way."
I happen to be somewhat inexperienced with Linux in general and the Raspberry Pi 2 in particular. Nonetheless, I have installed Raspbian Jessie Lite (Version: March 2016, Kernel version: 4.1) and have also performed these commands:
(//Having downloaded Current API Installer: 1.9.2 (includes API 1.8.1 - 11th Jan 2016) (Installer Released: 1st Mar 2016))
chmod 755 SDRplay_RSP_MiricsAPI-1.9.2.RPi.man
./SDRplay_RSP_MiricsAPI-1.9.2.RPi.man
My setup is as follows: The SDRplay is connected directly using USB to one of the ports on the Raspberry Pi 2 itself.
From this point on, I am uncertain how to continue. I have used the lsusb command and it does have the line:
Bus 001 Device 005: ID 1df7:2500
This seems to confirm that the device is being recognized, at least at a basic level.
Now, I have previously had success getting the SDRplay to work on other Linux devices (using Intel x86 CPUs, never on an ARM based device, having tried on the BeagleBone Black), so I am not totally clueless.
My question is thus:
What are the minimum steps needed to get the SDRplay working on the Raspberry Pi 2? I would like to at least be able to write my own C++ code, making use of the API Specification, and to have some kind of existing SDR software running to test/play around with.
I hope this post can be helpful to others who have the same level of knowledge as I do here, thanks!! :D
Last edited by SoulFinderLLC on Thu Jan 01, 1970 12:00 am, edited 0 times in total.
Re: Raspberry Pi 2 + SDRplay: Setup Guide?
Postby sdrplay » Fri Apr 08, 2016 6:25 am
First of all make sure udev is setup correctly so that you have the right permissions to talk to the RSP. Check if you have the following file, if not create it using sudo nano...
/etc/udev/rules.d/66-mirics.rules
it should just have one line in it...
SUBSYSTEM=="usb" ATTR{idVendor}=="1df7" ATTR{idProduct}=="2500" MODE:="0666"
Then you will need to restart udev...
sudo service restart udev
and then disconnect and reconnect the RSP.
Then you have 2 options, to either install SoapySDR/SoapySDRPlay - this is a generic control library that supports a variety of hardware including the RSP. To build/install it see: https://github.com/pothosware/SoapySDR/wiki and https://github.com/pothosware/SoapySDRPlay/wiki
Once both of these are installed, typing SoapySDRUtil --probe=sdrplay should produce an output without any errors.
Alternatively you can program for the API directly. On our Raspberry Pi page (http://www.sdrplay.com/raspberrypi2.html) you will see the API specification and an example of the control code in the back. There are also some example code on our github repository: https://github.com/SDRplay showing how we have controlled and received samples from the RSP.
If you want to use the dump1090 ADS-B decoder with the RSP, the version to use on the Raspberry Pi at the moment is: https://github.com/SDRplay/dump1090_sdrplus - there is a build_libs.txt file to explain what needs to be built for that application.
If you have any specific programming issues related to the RSP, please let us know and we'll try to help you. An email to support@sdrplay.com is the best way to do that.
SoulFinderLLC
Postby SoulFinderLLC » Sat Apr 23, 2016 1:08 am
I appreciate this reply, it helped exactly and everything worked (I got it working a couple weeks ago, just didn't get around to this reply until now)!! I am in the process of writing a detailed guide so that people in my position, in the future, won't feel so lost. If it is good enough, maybe it can replace the "None at this time - the Linux documentation may get you some way." line under "Raspberry Pi 2 Specific Documentation" on the main site. I will post it here later. :D
sdrstez
Postby sdrstez » Thu Sep 15, 2016 7:50 am
Hi SoulfinderLLC,
I am struggling to get the RSP working with my Pi3.
Using the SDRPLAY instructions gets me so far then nothing.
Is there a simpler setup guide available for folks with very little knowledge of raspberry Pi?
SoulFinderLLC
Postby SoulFinderLLC » Fri Sep 30, 2016 9:03 pm
I am sorry for never getting around to posting the guide I had promised. I don't know to what extent the instructions for the Pi2 would transition to the Pi3, but I will try to have something written up soon.
The very day your reply came in, this forum and the greater site all went down and I could not access anything. I then forgot about it, so sorry for the late reply.
F1BJB
Postby F1BJB » Sat Oct 01, 2016 5:02 am
Hi
I made various test and comparisons between Orange PI and Intel based mini PC's for SDR.
Using gqrx under Linux and SDRtouch under Android and various softwares under Windows 10.
My conclusion is that Intel devices are much more suited due to the mathematical computations involved.
May be a good use for PI would be to stream the complete output of the receiver on a gigabit network.
I have yet to investigate that .
For narrow band uses like with a fun cube dongle the PI is OK but even decoding an FM stereo signal is
hard to do and needs good cooling of the CPU.
K8UT
Postby K8UT » Sun May 28, 2017 9:16 pm
Did that setup guide ever get published somewhere? I am similarly stuck.
I installed the API. Ran LSUSB, see the SRDplay in a USB port. Checked UDEV, and the device is listed in the rules. Installed and compiled SoapySDR. Unplugged and plugged the SDR. Everything seems right.
Next I enter "SoapySDRUtil --probe=sdrplay" and get a console screen listing driver=null, hardware=null, Channels: 0 Rx, 0 Tx; and Timestamps = NO
huh? Seems that I must have missed an important step somewhere...
-larry
octave9
Postby octave9 » Mon May 29, 2017 11:11 am
There are two parts of the SoapySDR and the output you're getting suggests 'SoapySDRPlay' isn't installed. I pasted how that install went for me:
john@Mint-18 ~/SDR_Dev $ git clone https://github.com/pothosware/SoapySDRPlay.git ./SoapySDRPlay
Cloning into './SoapySDRPlay'...
remote: Counting objects: 293, done.
remote: Total 293 (delta 0), reused 0 (delta 0), pack-reused 293
Receiving objects: 100% (293/293), 73.32 KiB | 0 bytes/s, done.
Resolving deltas: 100% (197/197), done.
Checking connectivity... done.
john@Mint-18 ~/SDR_Dev $ cd SoapySDRPlay
john@Mint-18 ~/SDR_Dev/SoapySDRPlay $ mkdir build
john@Mint-18 ~/SDR_Dev/SoapySDRPlay $ cd build
john@Mint-18 ~/SDR_Dev/SoapySDRPlay/build $ cmake ../
-- The CXX compiler identification is GNU 5.4.0
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Build type not specified: defaulting to release.
-- Found libsdrplay: /usr/local/include, /usr/local/lib/libmirsdrapi-rsp.so
-- LIBSDRPLAY_INCLUDE_DIRS - /usr/local/include
-- LIBSDRPLAY_LIBRARIES - /usr/local/lib/libmirsdrapi-rsp.so
-- Performing Test HAS_STD_CXX11
-- Performing Test HAS_STD_CXX11 - Success
-- Configuring done
-- Generating done
-- Build files have been written to: /home/john/SDR_Dev/SoapySDRPlay/build
john@Mint-18 ~/SDR_Dev/SoapySDRPlay/build $ make
Scanning dependencies of target sdrPlaySupport
[ 25%] Building CXX object CMakeFiles/sdrPlaySupport.dir/Registation.cpp.o
[ 50%] Building CXX object CMakeFiles/sdrPlaySupport.dir/Settings.cpp.o
[ 75%] Building CXX object CMakeFiles/sdrPlaySupport.dir/Streaming.cpp.o
[100%] Linking CXX shared module libsdrPlaySupport.so
[100%] Built target sdrPlaySupport
john@Mint-18 ~/SDR_Dev/SoapySDRPlay/build $ sudo make install
Install the project...
-- Install configuration: "Release"
-- Installing: /usr/local/lib/SoapySDR/modules0.6-dev/libsdrPlaySupport.so
-- Set runtime path of "/usr/local/lib/SoapySDR/modules0.6-dev/libsdrPlaySupport.so" to ""
john@Mint-18 ~/SDR_Dev/SoapySDRPlay/build $ sudo ldconfig
john@Mint-18 ~/SDR_Dev/SoapySDRPlay/build $ SoapySDRUtil --info
Lib Version: v0.6.0-gb0ebaecf
API Version: v0.6.0
ABI Version: v0.6-dev
Install root: /usr/local
Search path: /usr/local/lib/SoapySDR/modules0.6-dev
Module found: /usr/local/lib/SoapySDR/modules0.6-dev/libsdrPlaySupport.so
Loading modules... done
Available factories...null, sdrplay,
Then the op of 'SoapySDRUtil --probe' is much more interesting (Serial number changed):
john@Mint-18 ~/SDR_Dev/SoapySDRPlay/build $ SoapySDRUtil --probe
Probe device
fwDownload: FW image size = 6083
mir_sdr_usb_GetDevices Dev0:vid=1df7 pid=3010 rev=0207 serno=0000000000 bus=001 port=004 devAvail=1
mir_sdr_usb_SetDeviceIdx idx=0 numDevices=1
Opened device with idVendor = 0x1df7 idProduct = 0x3010 fwVersion = 0x0207 busNum = 001 portNum = 004
-- Device identification
  driver=SDRplay
  hardware=2 0000000000
  mir_sdr_api_version=2.090000
  mir_sdr_hw_version=2
-- Peripheral summary
  Channels: 1 Rx, 0 Tx
  Timestamps: NO
  Other Settings:
       [key=rfgain_sel, default=4, type=string, options=(0, 1, 2, 3, 4, 5, 6, 7, 8)]
     * Antenna Select - Antenna Select
       [key=ant_sel, default=Antenna A, type=string, options=(Antenna A, Antenna B)]
     * AMport Select - AM Port Select
       [key=amport_ctrl, default=AntA//AntB, type=string, options=(AntA/AntB, Hi-Z)]
     * ExtRef Enable - External Reference Control
       [key=extref_ctrl, default=true, type=bool]
-- RX Channel 0
  Full-duplex: YES
  Supports AGC: YES
  Stream formats: CS16, CF32
  Antennas: RX
  Corrections: DC removal
  Full gain range: [0, 39] dB
    IFGR gain range: [20, 59] dB
    CORR freq range:  MHz
  Sample rates: [0.25, 10] MHz
mir_sdr_usb_ReleaseDeviceIdx 0
K8UT
Postby K8UT » Wed May 31, 2017 2:27 pm
John - THANK YOU!
I followed the instructions you provided and am now getting some valid results from SoapySDR.
NeilP
Postby NeilP » Tue Oct 30, 2018 1:14 pm
I admit, I have not yet started yet to get the RSP1a to run on the pi with a Raspberian lite headless system
I have used the SDRPlay Pi image and got it working directly but I want to try running it on a Pi 3B+ as a headless system and Raspberian lite.
So all I want running on the pi is Soapy Remote I think it was called..
Did the Tutorial for that ever get written?
EDIT.
maybe this will be what I need
https://ansi.23-5.eu/2018/01/sdrplay-re ... omment-482
