Frequency Plotter for OS X
DVE
Post by DVE » Sun Apr 10, 2016 12:43 pm
Hi guys,
I finished my SDR based app :)
It can scan the frequency range and display the graphs. I've checked different ones, by no one was supporting SDRplay, so I wrote my own.
It use Soapy SDR and was tested with my receivers SDRplay, HackRF and RTL-SDR.
I also write ObjectiveC wrapper for the Soapy library, so it can be used in Objective-C/Swift applications.
App is free, sources (Swift/ObjectiveC) and binary are available:
https://github.com/dmitryelj/SDR-Frequency-Plotter-OSX
Screenshot:
Screenshot
Any feedback is welcomed.
Next step, I'm going to make the app, that will do schedule recording (will be useful to write NOAA records at night:).
Sasan
Re: Frequency Plotter for OS X
Post by Sasan » Sun Apr 10, 2016 3:28 pm
Hi
It crashes because it's searching for a .dylib in a hard-coded path (from your development system)
I've opened an issue on github.
DF2HF, NM9A, EP2C
DVE
Post by DVE » Mon Apr 11, 2016 8:37 am
Problem is, there are no hardcoded paths in the application. It looks like, you need to install SoapySDR in OS X before using the app.
Can you please do this, using the instruction?
1) Download SoapySDR-master.zip from https://github.com/pothosware/SoapySDR (use "download zip")
2) Build using this guide https://github.com/pothosware/SoapySDR/wiki/BuildGuide (see "Unix instructions" section)
Later I'll make GUI installer once :)
