Connection to Yaesu FTDX3000
shortwave100
Postby shortwave100 » Thu May 12, 2016 8:50 pm
I'd like to buy an sdrplay to usewith my Yaesu.
But I have no clue how/where I would get a cable to connect the radios IF out to the sdrplay.
Do I need to somehow make one ? What connectors and type of cable do I need ?
Can anybody point me to a source of information on this ?
Cheers
Last edited by shortwave100 on Thu Jan 01, 1970 12:00 am, edited 0 times in total.
Harry
Re: Connection to Yaesu FTDX3000
Postby Harry » Fri May 13, 2016 12:56 pm
I believe the FTDX-3000 has an RCA port. If so, you will need a shielded coaxial cable with RCA male on one end and SMA male on the other. With my HF rigs I use 50 ohm mini-coaxial cables for this purpose - either RG-174 or RG-316 - but that's just my preference. When ordering the cable be sure the SMA connector is designated SMA and not SMA-RP (reverse polarity). SMA-RP is used for other applications such as WiFi. There are a number of sources for the cable on eBay, Amazon and the internet.
You will also need a USB cable. I recommend one that is shielded and has a ferrite choke.
Hope this helps.
Harry WE1X
shortwave100
Postby shortwave100 » Fri May 13, 2016 9:21 pm
It does help thanks
As far as Amazon...what sort of search terms ? I tried 'SDR cable', 'SDR connector'...to no avail.
Harry
Postby Harry » Fri May 13, 2016 9:49 pm
shortwave100 wrote:It does help thanks
As far as I know there is no "SDR Cable" or "SDR connector". What you want is a generic 50 ohm mini-coax cable with an RCA male and SMA male.
So try something like this: "RG-316 cable with RCA Male to SMA Male"
W9ZO
Postby W9ZO » Sat May 14, 2016 2:40 am
shortwave100
Postby shortwave100 » Sat May 14, 2016 8:22 am
Thanks for that link.
Does anybody know.....specific to the FTDX3000...am I ok to go ahead and transmit when the sdrplay is connected to the IF OUT with this cable ? ....without fear of feeding back to the sdrplay is any way ?
I know these are basic questions but I guess that's what my knowledge is....basic !
Postby jon » Sun May 15, 2016 6:47 am
It is fine to connect to the IF out because it is part of the receiver's signal chain and is therefore protected during transmit. If you join the Facebook Group on https://www.facebook.com/groups/sdrplay/ you can do a search on FTDX3000 and see a lot of threads discussing panadapter use.
Good luck and 73, Jon
shortwave100
Postby shortwave100 » Sun May 15, 2016 8:58 pm
Thanks for the info
NN4F
Postby NN4F » Wed Jun 08, 2016 7:34 pm
It works fine, you can TX, and also it works better on the RF out, the advantage is that gives you several more receivers across several bands using the 8 mhz wide bandwidth...
Paul - NN4F
Lifeson
Postby Lifeson » Thu Aug 04, 2016 9:40 pm
i am having issues with running the rf out on the back of the radio to the sdrplay. i am not getting reception.it works when i run an antenna directly up to it.. i got the cable rca to sma from the amazon link posted on this thread. thanks for any help!
73
Danny
KB8VFA
