We have just released SDRuno version 1.13 which adds the much requested ‘IF Out’ facility for Panadapter use. It also includes the following updates:
Bug Fixes
• Fixed RSP2 IF AGC/gain slider display issues
Updates
• Added IF Output mode for transceivers
• Added 250 Hz to frequency step size list
• Default page in the settings panels is now the left most page each time SDRuno is started
• Added RSP2 IF GR/Gain value
• Added Factory Reset in the Main Window OPT menu (1st Instance only)
• Improved power function error handling
• Added support for Sub Modes, Filter BW and Port Selction in the Memory Panel
• Changed RDS window colour scheme to match other windows
• Added new hotkeys ‘v’, ‘-‘ and ‘+’ which are for VFO, Out and In zoom buttons in the SP1 window
• Hotkey ‘b’ now opens AND closes the memory panel
• Changed the default sync Rig->VRX setting to true
• API – RefClk o/p no longer stops when the master RSP2 stops streaming
To get this latest version, go to http://www.sdrplay.com/downloads
(Documentation is in ‘release notes’)
