API library fails to install
cyberdave
Postby cyberdave » Tue Jan 16, 2018 12:05 pm
I am using Antergos and have just received a RSP1A
when I execute
./SDRplay_RSP_API-Linux-2.11.1.run
I get the following out put
Verifying archive integrity... All good.
Uncompressing SDRplay RSP API Install Package V2.11.1
Installing SDRplay RSP API library 2.11...
Press space when prompted with --More-- to read the license agreement.
SDRplay Limited
END USER LICENCE AGREEMENT
(content removed to save space)
Press y and RETURN to accept the license agreement and continue with
the installation, or press n and RETURN to exit the installer [y/n] y
./install_lib.sh: line 17: arch: command not found
Architecture:
API Version: 2.11
Remove old libraries...
[sudo] password for david:
Install /usr/local/lib/libmirsdrapi-rsp.so.2.11
cp: cannot stat '/libmirsdrapi-rsp.so.2.11': No such file or directory
chmod: cannot access '/usr/local/lib/libmirsdrapi-rsp.so.2.11': No such file or directory
Remove old header files...
Install /usr/local/include/mirsdrapi-rsp.h
Udev rules directory found, adding rules...
Libusb found, continuing...
Finished.
Re: API library fails to install
Postby sdrplay » Tue Jan 16, 2018 3:55 pm
Strange for a release of Linux to not have the arch command. Can you get it for that OS or maybe alias it to something that returns the arch?
The installer uses 'arch' to install the correct API.
cyberdave
Postby cyberdave » Tue Jan 16, 2018 7:39 pm
Thanks for the suggestion
So I added an alias as follows
alias arch='uname -m'
If I now type "arch" on the command line I get "x86_64" as output
When I run the install again I get exactly the same error message. The installer doesn't seem to know about the alias. I suspect my limited knowledge of linux could part of the problem.
Postby sdrplay » Tue Jan 16, 2018 8:04 pm
The script runs as root via sudo so it won't use your user aliases.
Maybe put a script called arch in /usr/bin ?
cyberdave
Postby cyberdave » Wed Jan 17, 2018 12:18 pm
Thank you. I did that and it has now installed successfully.
Then I installed SoapySDR and SoapySDRPlay without any problems.
Then check info as per non windows flow. It appears there is some sort of a path problem. I have also added the blacklist file.
[david@david ~]$ SoapySDRUtil --info
Lib Version: v0.7.0-g2a266d60
API Version: v0.7.0
ABI Version: v0.7
Install root: /usr
Search path: /usr/lib/SoapySDR/modules0.7
Search path: /usr/local/lib/SoapySDR/modules0.7
Module found: /usr/lib/SoapySDR/modules0.7/libLMS7Support.so (18.01.0-e5cde28)
Module found: /usr/lib/SoapySDR/modules0.7/librtlsdrSupport.so (0.2.4-3932325)
Module found: /usr/lib/SoapySDR/modules0.7/libsdrPlaySupport.so
dlopen() failed: libmirsdrapi-rsp.so.2.11: cannot open shared object file: No such file or directory
Module found: /usr/local/lib/SoapySDR/modules0.7/libsdrPlaySupport.so
Available factories... lime, rtlsdr
Available converters...
- CF32 -> [CF32, CS16, CS8, CU16, CU8]
- CS16 -> [CF32, CS16, CS8, CU16, CU8]
- CS32 -> [CS32]
- CS8 -> [CF32, CS16, CS8, CU16, CU8]
- CU16 -> [CF32, CS16, CS8]
- CU8 -> [CF32, CS16, CS8]
- F32 -> [F32, S16, S8, U16, U8]
- S16 -> [F32, S16, S8, U16, U8]
- S32 -> [S32]
- S8 -> [F32, S16, S8, U16, U8]
- U16 -> [F32, S16, S8]
- U8 -> [F32, S16, S8]
Postby sdrplay » Wed Jan 17, 2018 1:56 pm
try...
export LD_LIBRARY_PATH=/usr/local/lib:$LD_LIBRARY_PATH
SoapySDRUtil --info
if successful you can then...
SoapySDRUtil --find=sdrplay
and
SoapySDRUtil --probe=sdrplay
cyberdave
Postby cyberdave » Wed Jan 17, 2018 2:58 pm
Thanks again. That seems to have sorted detection of the device.
API Version: v0.7.0
ABI Version: v0.7
Install root: /usr/local
Module found: /usr/local/lib/SoapySDR/modules0.7/libsdrPlaySupport.so (0.1.0-ca7e028)
Available factories... sdrplay
- CS32 -> [CS32]
- S32 -> [S32]
[david@david ~]$
And...
[david@david ~]$ SoapySDRUtil --find=sdrplay
Found device 0
driver = sdrplay
label = SDRplay Dev0 RSP1A 255 1716004493
So now I installed CubicSDR. When I launch it a dialog box appears with a selection of installed devices to select from. The SdrPlay does not appear in the list yet my RTL-SDR does if plugged in. I understand CubicSDR may be out of your support arena.
cyberdave
Postby cyberdave » Thu Jan 18, 2018 8:29 am
I see elsewhere on the forum that the RSP API will not currently work with libusb greater than 1.0.19. My OS has version 1.0.21-2. Could this be the problem and if so are there plans to resolve this?
cyberdave
Postby cyberdave » Fri Jan 19, 2018 10:40 am
After downgrading libusb to 1.0.19-1 I am still unable to see SDRPlay as a detected device in CubicSDR
Postby sdrplay » Fri Jan 19, 2018 12:59 pm
If
finds the device then that is enough to prove it's working. If CubicSDR cannot see SoapySDR devices try...
CubicSDR
If you are trying to start CubicSDR any other way you will need to make sure the LD_LIBRARY_PATH variable is set permanently.
