RSPduo and Qt-dab
RSPduo and Qt-dab
Hi there !
Does Qt-dab software (to listen to DAB stations) work with a RSPduo ?
Attached is a screenshot of the "no library or device" that shows up when selecting 'sdrplay' as a device'.
Thanks.
Thanks.
- qt.JPG (264.92 KiB) Viewed 21877 times
Re: RSPduo and Qt-dab
The following message also shows : "failed to locate API registry entry, error = 0"
Any progress on getting DAB working with the RSPduo under WIndows yet?
I just received the following from Jan, Qt-dab author :
"I had contact with Andy from sdrplay. The qt-dab software does not need the v3.0 library, it all just works fine with the 2.13 library.
So, you have to install the 2.13 API from sdrplay - it can coexist with the 3.0 library.
The 2.13 library has partial support for the duo: you just use one of the tuners then, but that is all what is needed.
The sdrplay site has it its download section the 2.13 api"
Will give it a try tomorrow
To SDRplay Team : once API v2.13 is installed, does the v3.0 library remain the default one ? (in case I want to run dual tuner)
I just downloaded v2.13 but not installed yet ...
Qt-dab works after I installed API 2.13, but I still haven't managed to decode the only multiplex available at my location. The strange thing is that reception of this multiplex is quite easy with a tiny Sony radio (XDR-P1DBP) or a Roberts radio (Stream 93i).M1CRX wrote:Any progress on getting DAB working with the RSPduo under WIndows yet?
I carefully tried to adjust at best the gain slider, in vain. The "Sync' detector sometimes blinks for a second or two, that's all.
I also gave a try to sdr-j-fmreceiver (0.99) contained in Qt-dab zip folder : only my loudest FM stations could be heard, even adjusting properly the gain slider below overloading point (tones of 'ghosts frequencies' appear otherwise).
Of course, no problem to catch dozens of stations when running SDRuno.
I don't know if both 'issues' are linked but there's something going wrong.
Jan just sent me a new release of Qt-dab 2.0 and ... At last it works !
- dab.JPG (174.97 KiB) Viewed 21598 times
.....unfortunately it now doesn't work with the RSP2! Comes up with "Warning SDRplay:no library or device" and "Could not find mir_sdr_rspDuo_TunerSel"
Previous release of Qt-dab v2.0 worked just fine.
Noel.
Noel.
Hello Noel,
Have you installed release 2.13 of the API? This is required for this new version of qt-dab.
Thanks Support
Installed 2.13 and all now fine. I hadn't installed earlier as it is listed as "For developers only" on the download page.
Is there any way of checking via SDRUno which API is installed?
Thanks for the update and assistance.
Noel.
Noel.
