SDRUNO v1.3 issue
RichardG062
SDRUNO v1.3 issue
Post by RichardG062 » Fri Mar 22, 2019 4:52 pm
I have uninstalled my earlier version of SDRUNO and installed v1.3 on occasions I have to set the IF to zero to correct the audio however after changing and upon exiting I get memory panel modified warning as attached. However if I choose to save it just appears to save the bank of frequencies. any ideas as to how to correct this issue as it appears to be intermittent when you switch between a stored frequency one of the bands?
Regards
Richard Griffith
sdrom33
Re: SDRUNO v1.3 issue
Post by sdrom33 » Fri Mar 22, 2019 7:05 pm
This happens if you use scanner :cry:
finndxer
Post by finndxer » Sat Mar 23, 2019 12:44 pm
It's because of that...
RichardG062
Post by RichardG062 » Sun Mar 24, 2019 11:04 am
Many thanks after un-checking that box the problem seems to have been fixed!
Richard Griffith
