No Record Audio
No Record Audio
I can record, but when I play the file, there is no audio. Does anyone have any tips for me? Thank you for your help
Re: No Record Audio
Jim,
It was thought that 1.02 would have fixed this, but it did not.
Guess we will have to wait for a future update to fix this and the inability to use the squelch. Other than that, I'm really enjoying SDRuno ... especially since I figured out (and corrected!) that I set the manual Gain Reduction way too high.
Mike
Mike
Sony ICF-2010 Sangean ATS-909X Icom IC-R71A & IC-7300 Tecsun PL-660 Kenwood R-1000 & R-5000 Yeasu FRG-7 SDRplay RSP2 & RSPduo Airspy HF+ & Discovery JRC NRD-535D CountyComm GP-5/SSB Pixel RF Pro-1B Wellbrook ALA1530LNP
Re: No Record Audio
What are you trying to play the file in? After making a recording I cant' play it in Windows Media Player (for instance) as it is an IQ file so will just be silence. But opening up in Data File Analyser that comes with SDRConsole it opens and plays fine.
Stephen
Stephen
Re: No Record Audio
Thank you Stephen. I'll give that a try. I thought they were regular wav files and was trying to play them in windows media player
Re: No Record Audio
I have the same problem:
With the right mouse button I select the destination map where the recorded file should be saved.
Then I click the record button. This seems to work, but after the recording has been stopped I can't find the expected recording file in the map.
Does anyone have a solution or we have to wait for the next version?
Re: No Record Audio
I use Audacity to record. I wish UNO V1.11 just recorded in MP3 format that would play on anything.
