Problems with receiving Bands
ON FM BAND the software works ok But on 40 meters or any other bands I get nothing, no signals, I have tried two different antenna's Longwire and Discone. Can't figure out what setup I have wrong I am trying all the ham radio bands in upper and lower and nothing, any help appreciated.
Steve
Steve
- CAN NOT GET SIGNALS
- 40 meter.JPG (215.92 KiB) Viewed 25484 times
- WORKS OK
- Capture.JPG (222.7 KiB) Viewed 25484 times
Re: Problems with receiving Bands
Steve
You could try downloading HDSDR and trying it out, from this page:
http://www.hdsdr.de/
HDSDR IMO is easier to set up and get running, and maybe just because I've used it longer, it's easier to find and see the settings. That would at least maybe narrow down the problem, is it some setting in SDRUno, or something wrong for both SDRUno and HDSDR.
Hi Steve,
Can you email support@sdrplay.com with your RSP serial number? Have you another SDR device that you can try to determine whether you might have an antenna problem? As WhoaNellie suggests, it might be worth trying HDSDR also. If you have the same issue with HDSDR, it might imply a hardware problem of some sort.
Yours sincerely
Yours sincerely
Thank you for your help I emailed the info you requested and also two screen captures, If there is anything else I can provide do not hesitate to ask me.
Steve
Steve
Hi Saint,
I have the same problem as you
On FM Boradcast I don't have problem but when I'm trying to liste HF Band, no RX.
I mean it's necessary to put a IF anywhere.
I'm using a FT-2000 with IF Frequ
73 de Paul, ON6DP
73 de Paul, ON6DP
73 de Paul, ON6DP / OP0P
