Possible to get UTC To Show 24 Hr Format
NoelC
Post by NoelC » Fri Jan 05, 2018 1:21 pm
The UTC time stamp in the MAIN window is only shown in 12 hour format.
Is it possible to tweak a setting to change it to 24 hour format?
If not, SDRuno maintainers, please consider this a request to add the capability. Make it a secret registry key if you'd rather not spend the time coding the UI for another option.
Thanks.
-Noel
DanubeBCL
Re: Possible to get UTC To Show 24 Hr Format
Post by DanubeBCL » Fri Jan 05, 2018 1:42 pm
Depends on your systemwide time format setting. I believe yours is hh:mm:ss AM/PM.
No Problem with localisations which use HH:mm:ss.
But nevertheless: UTC should not show AM/PM depending on system localisations. UTC is a 24h format. This should be corrected in SDRuno.
Post by sdrplay » Fri Jan 05, 2018 2:42 pm
This is addressed in 1.22 which will be released shortly.
Post by Paul » Fri Jan 05, 2018 3:53 pm
May I say that this has not been an issue for me as uno appears to reflect computer's time and date settings as selected, so 24 hour format is fine as long as the computer is set to reflect UTC.
This may be problematic for those wishing to have their computer on local time, but in my own case, this computer is more-or-less dedicated to SDR use, so no problem.
2018-01-05 (2).png (59.6 KiB) Viewed 21246 times
Post by Paul » Fri Jan 05, 2018 4:10 pm
Sorry - UTC not selected in first one - now selected - computer in 24Hr format.
2018-01-05 UTC.jpg (51.46 KiB) Viewed 21243 times
NoelC
Post by NoelC » Mon Jan 08, 2018 6:35 am
Thanks. In my case I'd prefer 12 hour time for the local computer time display in general, and 24 hour time for the UTC selection. Looking forward to 1.22!
-Noel
NoelC
Post by NoelC » Thu Jan 25, 2018 11:03 pm
I can confirm it's working just as I want in 1.22: 24 hr UTC even though my system is set to display local time in 12 hr format.
-Noel
