Ver 1.22 Menus
hamrad
Ver 1.22 Menus
Post by hamrad » Sat Mar 24, 2018 12:46 pm
I see you can change the step size for each mode with a pulldown menu but how to you get that menu.
Tom
Re: Ver 1.22 Menus
Post by sdrplay » Sat Mar 24, 2018 1:46 pm
right click on the frequency display in the RX control window
JJ_in_TN
Re: Ver 1.22 Menus
Post by JJ_in_TN » Fri May 11, 2018 4:22 am
This information really belongs in the manual. I searched quite a long time before finding this post. A search on "step" in the manual pdf gets you 37 hits but none related to this function.
73
JMG
Re: Ver 1.22 Menus
Post by JMG » Fri May 11, 2018 8:03 am
And how to store the new setting?
Re: Ver 1.22 Menus
Post by Mike2459 » Fri May 11, 2018 3:07 pm
Pages from v1.jpg (130.52 KiB) Viewed 18493 times
AFAIK there is no provision in SDRUno to store user defined bandwidth settings.
Section 3.8 of SDRUno version v1.2 manual, not in 1.22 version!!
3.8 Changing the tuning step
Each Mode has a default tuning step size. This can be changed by Right-clicking on the RX Control frequency dial: the dial step menu will popup. Select the desired tuning step.
AM = 1 kHz
SAM = 1 kHz
FM = 5 kHz
CW = 10 Hz
DSB = 250 kHz
LSB = 250 kHz
USB = 250 kHz
