SDRUno instability
Posted: Fri Jun 09, 2017 1:49 pm
I'd like some input here. I use SDRUno / RSP2 both locally and over my LAN with RDP. I am finding some minor instability used locally and more pronounced instability used remotely over my LAN with RDP. Host PC is an i7 / 8GB RAM / USB3 ports, running up to date Windows 10 x64. My RDP sessions run on a Lenovo Thinkpad X1C v3 with an i7 and up to date Windows 10 x64. Router is a Netgear WNDR3700v2 running OpenWRT. Ethernet (CAT5e) from host PC to router. 5GHz WiFi to the RDP client.
1. Occasionally it seems as though the RSP2 simply stops and the waterfall becomes solid vertical stripes as though the something was repeating the last received sample indefinitely. I have seen this locally AND remotely via RDP. It does not happen often but it does happen. It never seems to occur spontaneously.... just simultaneously with some other SDRUno action.
2. Often, and usually only once per session, RDP and SDRUno will simply freeze. Usually RDP will report that it has lost connection. When it auto connects again, SDRUno reports queuing errors that can be dismissed with multiple clicks on OK. However, this often results in SDRUno no longer being able to communicate with the RSP2. The only way to restore operation is to either unplug and re-plug the RSP2 or reboot. This does occur spontaneously, without any user input.
3. Often, the text in the memory panel box becomes black instead of the usual yellow. This makes it VERY hard to read
This issue seems to be confined to connections over RDP..... I don't recall seeing this one locally.
Since my preferred use is RDP from laptop to host PC, I would like to find a solution to these issues. SDRUno is an otherwise superb product. I initially thought this might be a networking issue (and it still may be). When I switched from the stock Netgear router firmware to OpenWRT, the issues did seem to get better. But they never went completely away. It is easy to blame RDP but I use RDP a LOT (including other SDR software) and SDRUno is the only program that has an issue with it.
I'm looking for other user's input and/or input from the SDRUno programmers.
