SDRUno vs. Others
Posted: Thu Jan 18, 2018 1:28 am
by rzar66
Hello all. New to SDR radios and a fairly new ham. My question is how does SDRUno work better with my RSP1A vs. other programs like SDR Console? Or what can SDRUno do that SDR Console cannot with my RSP1A?
Ryan
Re: SDRUno vs. Others
Posted: Sat Jan 27, 2018 12:54 am
by AB4RW
i have tried all the SDR programs, UNO, HDSDR,SDR CONSOLE, and something play, came back to UNO, depending what you want to do, i use mine as a pan adapter on my 590SG, once you get past the learning curve youll enjoy. TIP! watch the videos the have posted, tremendous help. but figure out what you want to do first
AB4RW
Posted: Sat Jan 27, 2018 11:22 pm
by rzar66
Thanks for the reply. I also use it as a panadapter for my 590SG. I like both Uno and SDR Console but with Uno the audio drops out if I look at more the 5 MHz of spectrum. With Console I can look at the whole 10 MHz with no problems. Don't understand that because neither program is taxing my computer. Just wondering if I am missing out on anything buy using SDR Console instead of SDRuno.
Posted: Sun Jan 28, 2018 1:13 pm
by pgoelz
Your apparent USB bandwidth issue aside, I find most modern SDR software is fairly comparable in its ability to receive, filter and demodulate. The difference is in configuration, layout and usability. In that respect, I find SDRUno to be well ahead of all the other SDR software I have tried. For me at least, it is just the right blend of traditional radio layout / presentation plus advanced SDR-only features. And the fact that it was included at no extra cost with my RSP2 was a big plus.
Posted: Mon Jan 29, 2018 10:13 pm
by rzar66
Well I will try to figure out why the audio is cutting out with Uno. I know I have more than enough computer for it.
Posted: Mon Jan 29, 2018 11:02 pm
by pgoelz
rzar66 wrote:Well I will try to figure out why the audio is cutting out with Uno. I know I have more than enough computer for it.
Try a different USB port for starters. Heck, try all of them
Depending on your motherboard, some may be faster than others. Also, some USB ports are grouped together on an internal hub. If that places the SDR on the same hub as another traffic hog, that could be an issue.
Posted: Tue Jan 30, 2018 9:11 am
by Mike2459
rzar66: My experience with SDRUno is similar to yours. I can operate on my Intel Core2 2.5 ghz Dell laptop at the full sample rate with 32 bit Windows 7 but on my Win 7 64 bit 3.2 ghz 10 core cpu system SdrUno chokes when the SR exceeds 5 Mhz. As pgoelz suggests, and I concur, the bottleneck may reside in USB not the CPU.
Unless you need to use SDRUno you can achieve higher sample rates with other software, such as SDR Console or HDSDR.
Posted: Tue Jan 30, 2018 9:16 pm
by rzar66
Here are the specs of my computer. Probably overkill for my Ham Radio needs but I got it on sale for a good price. I tried switching USB ports with no change to the audio issue with SDRuno. SDR Console runs flawlessly.
Processor & Memory:
AMD Ryzen 7 1700 Processor at 3.0GHz
16GB DDR4 (2-DIMM) RAM
Drives:
1TB 7200RPM SATA Hard Drive
DVD-Writer
Operating System:
Microsoft® Windows 10 Home (64 bit)
Graphics & Video:
4GB AMD Radeon RX 550 Graphics
Audio:
5.1 surround sound
Ports:
3x USB 3.0
1x USB 3.0 Type C
2x USB 2.0
1x HDMI
1x DVI
1x Display Port
1x Headphone-out/microphone-in combo jack
Multi-format Media Card Reader
Posted: Tue Jan 30, 2018 9:20 pm
by rzar66
Mike2459 wrote:rzar66: My experience with SDRUno is similar to yours. I can operate on my Intel Core2 2.5 ghz Dell laptop at the full sample rate with 32 bit Windows 7 but on my Win 7 64 bit 3.2 ghz 10 core cpu system SdrUno chokes when the SR exceeds 5 Mhz. As pgoelz suggests, and I concur, the bottleneck may reside in USB not the CPU.
I like both. I was just wondering if I am missing out on anything by not using Uno since it was developed with SDRplay in mind. I will probably stick with Console since it works "out of the box".
