@MajicM
Hi mate,
I thought about to give SDRuno v1.23 a try.
Ok, first of all, I use an RSP1A with SDRuno v.1.22 on a Windows 10 system and with the following steps I could use v.1.23 without any faults or errors so far, although there are still some graphical flaws like in version 1.22, also some minimal newer ones, too.
Maybe the following steps could be of any help for you
So, this is what I used to do first before I installled v.1.23:
1. I made sure no SDRPlay related software was running and unplugged my SDRplay RSP1A from my computer
2. I reset the registry settings via the windows start menu, sdrplay folder, "Reset SDRuno Registry Settings"
3. uninstalled via start menu, sdrplay folder, "SDRplay_Driver Uninstall"
4. head over to the windows control panel, programs and features, and uninstalled "SDRuno version 1.22"
5. did a reboot of windows
After windows has started and fully loaded I installed SDRuno v.1.23 and followed exactly the steps like the menus in the installation process showed me. Please make sure that you don't have plugged in your RSP2 pro before you install SDRuno v1.23! When installation was finished I started SDRuno. Before I press play I made all necessary settings in each window via their settings tab and also set my preferrred settings, too. If all that has been done I pressed play and used my SDRplay with SDRuno v.1.23 and I could use it for one hour without any faults and errors (I did not fully tested all functions, only the "normal" behavior for listening in different modes, filter settings etc. on shortwave and mw).
I returned to SDRuno v.1.22 as it has less graphical flaws and overall is suited much better for the RSP1A.
Most graphical flaws are the same as in version 1.22, for example in the "RX Control"- window, there is the big black shadow mark under "tab 15" / "tab MW", the whole tab field is slightly positioned more to the left side, if you take a close look under the s-meter window the first row of the tabs are not exactly positioned and as they are a bit smaller in size as the other tabs, it should've been positioned more to the right side, to have a more centered look und the s-meter window.
In version 1.23 in the "Main"-window, some white frames of a few tabs do have marks that extend beyond the corners.
Don't get me wrong, I like my RSP1A with SDRuno very very much, SDRuno is my preferred software for the RSP1A, the RSP1A is my preferred shortwave receiver at all (I use my IC-R75 and IC-R71 rarely/infrequently now), SDRuno is well done and professional made, has a professional design, it's a joy to work with and the whole team did a great job. My critiques are at the very highest level, nothing that would really bother most users and to be fair, most of these graphical flaws won't disturb you either, when you use your SDRuno. But I still hope that the team will make a more customizable and themeable SDRuno-version for the users in the near future
So, a little tweak here and there, nothing that would take much time or effort and gone were the graphical flaws
Ok, hope this was of any help/use, have a nice a day, kind regards,
73 Tom
