Band Change Not Following The Transceiver
Posted: Tue Jun 26, 2018 12:55 pm
by n3hkn
Yaesu FT-450D
When I change bands using the transceiver SDRuno does not change. All other joint operations seem to work ok.
Re: Band Change Not Following The Transceiver
Posted: Wed Jun 27, 2018 3:00 am
by Roger
When you switch bands like 80m to 40M you need to make sure the LO is unlocked in SDRuno if you want to track your transceiver. This will not be the case if you are using the band select keypad in SDRuno to pick a band. If you are using the keypad just unlock the LO after each band selection and you will be OK. Most of the time I just use the 2 MHz. sample rate with decimation of 1 or 4 and leave the LO unlocked and don't use the band select buttons. Then I use the transceiver to select the band I want and SDRuno just follows along.
