RSPDuo and two VAC streams
Posted: Fri Oct 19, 2018 5:24 pm
Having set up a single tuner of my Duo with the help of Roger (see Optimisation of IF and RF gains) I moved on to using the two tuners in Normal Dual mode. I then spent a day trying to get the other tuner working in the same way. I used VB VACs for streaming the output of the two tuners to separate applications. The problem I have is that despite setting the two up identically I could not get the same audio output levels. Everything indicated on the two instances of SDRUno look OK.
I am running Windows 7 and ASIO4All drivers.
Swapping the VACs swaps the output levels. Running the Duo in single mode and swapping the VACs gives the same Input level to the VACs. The same is true when using either tuner.
