New Vers. 1.3 Screen Size Adjusting: How, Please ?
Robert11
Postby Robert11 » Thu Mar 14, 2019 1:15 pm
Should probably know the answer to this, but just
can't seem to do it:
Have downloaded and installed correctly (I think) the latest 1.3 version.
When I click on the shortcut icon to open it up, yes, all
the expected screens are there.
But, they are really, really small.
a. How do I re-size all the screens, please ? And how to keep this new size as the "default" ?
b. And, just to check, where is the version being used shown ?
Bob
Re: New Vers. 1.3 Screen Size Adjusting: How, Please ?
Postby sdrplay » Thu Mar 14, 2019 4:12 pm
Hello Robert,
A number of the panels are a fixed size (Main Window, RX control panel, EX control panel, scanner panel and the recorder panel). The other panels (SP1, SP2, memory panel and the RDS information panel) can all be resized by dragging the bottom right hand corner of the window and in the SP1 case, right click on the arrow in the bottom right hand corner and there are some sizes it can snap to.
Robert11
From OP Again: Re: New Vers. 1.3 Screen Size Adjusting: How, Please ?
Postby Robert11 » Thu Mar 14, 2019 4:24 pm
Something just isn't right with this.
The older vesion had screens that were perfect. Right size and readable.
No problems.
I changed nothing on pc or on display.
Absolutely un-readable now, and literally impossible to use like it is.
On the screens that you can drag a corner, all that happens is that the
screen does get bigger, BUT the text still remains small and unreadable.
Can you please make it like what it was on previous versions ?
Truly unreadable the way it is now.
Or, let me know what to do ?
Hard to believe that I'm the only one with this "problem," or am I ?
Thanks, as always, for help,
Bob
Robert11
Forgot to mention: Re: New Vers. 1.3 Screen Size Adjusting: How, Please ?
Postby Robert11 » Thu Mar 14, 2019 4:27 pm
Forgot to mention:
Have a very normal pc, not a laptop.
Using program on an iMac via Parallels emulation.
All other programs, etc. look just fine.
Bob
Postby sdrplay » Thu Mar 14, 2019 4:59 pm
Robert can you download the 1.3 installer and reinstall it again.
Let me know what you find.
Robert11
For Andy: Re: New Vers. 1.3 Screen Size Adjusting: How, Please ?
Postby Robert11 » Thu Mar 14, 2019 5:47 pm
Did the new re-install, as you suggested.
Same problem. Impossible to use as all is just so, so small.
Something "wrong," as old(er) versions weren't like this.
Thoughts ?
Thanks for help, as always,
Bob
jrodh
Postby jrodh » Thu Mar 14, 2019 6:23 pm
So I had the same problem on my Microsoft Surface 4. I was able to correct the issue for now by:
1) right click on the SDRuno icon
2) select properties
3) select compatibility from the top menu
4) select "Change high DPI setting"
5) select the check box for " Override high DPI scaling behavior"
6) select "system" from the drop down menu
7) select OK
8) select Apply
9) try opening SDRuno again and hopefully it worked
-Jared
Postby sdrplay » Thu Mar 14, 2019 6:43 pm
I'm trying to understand what could have changed between releases. Is someone able to record a video showing the following (I would obviously provide 1.24 installer for this test)...
Start recording the video
Install 1.24
Start 1.24 and show it working
Install 1.3
Start 1.3 and show it failing
Show the OS display resolution and any scaling that is being applied
Stop recording the video
Send the video (or a link to it) to software@sdrplay.com
Let me know and I can provide 1.24 if you don't have it.
jrodh
Postby jrodh » Thu Mar 14, 2019 8:22 pm
Ok, I'm going to post a video to support in a little while.
Jared
Robert11
Postby Robert11 » Thu Mar 14, 2019 8:35 pm
Hi Jared,
It works; everything looks "normal" now.
Thanks so much.
Really nice of you to take the time; much appreciated.
May annoy you with some more of my dumb questions in
the future, but, for now, all is happiness.
You're a genius.
Regards,
Bob
