1.3 Unable to select WFM and SWFM
illllm
Post by illllm » Fri Mar 15, 2019 6:47 pm
I am unable to select WFM and SWFM modes in 1.3. Is this a bug? something to do with settings?
THanks much!
illllm
Re: 1.3 Unable to select WFM and SWFM
Post by illllm » Fri Mar 15, 2019 6:53 pm
Cannot receive anything FM.
Post by Tech_Support » Fri Mar 15, 2019 7:24 pm
Please ensure that you have a high enough final sample rate. It is not possible to select to select a demodulation bandwidth that is greater than the final sample rate you have set. There is no problem with either WFM or SWFM in release 1.3 as long as have a high enough final sample rate and this has always been the case.
Post by glovisol » Fri Mar 15, 2019 7:40 pm
Hi Illllm,
Ver 1.3 works fine in Broacast FM. Here below PIC showing settings. On second PIC signal is so strong the S Meter is pinned to the right!
Cheers,
ScreenHunter 334.jpg (197.19 KiB) Viewed 3897 times
ScreenHunter 333.jpg (202.55 KiB) Viewed 3897 times
illllm
Post by illllm » Fri Mar 15, 2019 8:06 pm
That odd...it works fine in the older version but does not work in 1.3. I will uninstall everything and reinstall. Hope that will fix it.
glovisol, how does yours shows DAB? I cannot get it to show that..
illllm
Post by illllm » Fri Mar 15, 2019 8:17 pm
Getting access violation now using the scanner
illllm
Post by illllm » Fri Mar 15, 2019 8:20 pm
one more error
Post by g1hbe » Sat Mar 16, 2019 12:50 pm
illlm - the DAB notch filter will only appear if you have the RSP1a or the RSPDuo. Other models do not have the hardware to implement it. My RSP2 only shows notches for MW and FM.
