Feedback for version 1.0b here
Re: Feedback for version 1.0b here
Windows 10 Pro, 1809, German Version:
doesn't start.
Installation procedure without problem, simply the application won't start. No error message.
Vy 73
Geri, DK8KW
doesn't start.
Vy 73
Geri, DK8KW
ok, changed over to UK, time and language too. the 1b version works is a regional problem. I live in Germany.
Last edited by Psyfreak3064 on Thu Jan 01, 1970 12:00 am, edited 0 times in total.
ok thanks - I'll pass that on to Steve.
Installed over the previous version and runs ok.
Locks up / crashes at seemingly random times when various parameters are changed while running.
With rsp2 pro input terminated there are spurious signals displayed which I assume are internally generated in the rsp2. How about a routine to detect these and remove them in the software as part of a calibration process.
Hola.
I guess it is a local problem with decimal numbers: point and comma.
I changed these separators and program runs like a charm.
Best regards.
ANgazu.
Best regards.
ANgazu.
Steve is aware of the issue and is working on a fix.
how can manually lna gain adjust ?
Steve
The beta version operates on Vista apart from scrolling the centre frequency
Mouse scrolling does not change any digits however the digit/s can be hi-lighted (and flash) with the mouse and changed by keyboard arrows and also new frequency can be entered from the keyboard
Early days but looks good - thanks
Brian
Brian
Version 1.0b runs okay for me. Windows 7/64.
I find that the new control for center frequency entry is actually more difficult to use. What would be much better would be a control such as that in SDRuno, SDRSharp, etc....i.e. each digit highlighted with a small line above or below the digit, and using the mousewheel and up/dn arrows to change value with automatic rollover.
I also find that at present, I like the spectrum display in SDRUno better because I can use & control FFT averaging regardless of frequency span, up to the full 10 mhz. I do realize that for large spans i.e. > 10mhz , averaging would be too slow and so that is the purpose of the new video filter. Bravo and thank you for that. Also, the spectrum display in SDRUno updates VERY quickly, even at 10mhz span. I think that SAS ver 0.9 did this also. So would be good in SAS if the display could update that quickly when using spans up to 10mhz, and then scan as it does now for spans higher than that.
Thank you Steve & SDRPlay team for your wonderful work in this. You are appreciated.
Waterfall Mode?
Many thanks for the new version. Unfortunately I miss the waterfall mode. Does it still exist? If so, where can I activate it?
73, Ralf
73, Ralf
