GNU radio RF playback - Reg
dinesh_gnu1
Post by dinesh_gnu1 » Tue Jun 26, 2018 10:29 am
Hi Team,
I am experimenting with GNU-radio companion and USRP with few exercise. But am not able to get it done precisely.
My setup is Linux Host PC(gnuradio-companion) ---- Ethernet ----> USRP ----> BTS simulator (with Antenna).
Test procedure:
1. BTS simulator is set with the RF freq - 937Mhz.
2. Recording the Time frames from the configured freq using GNUradio companion. (.grc file is attached below).
Center Freq - 937Mhz.
Channel Bandwidth - 200Khz
SAmple rate - 4Ms
Observation:
Gnu radio Freq FFT analyzer doesn't show up the spectrum from the configured center frequency. Instead complete 200Khz bandwidth is having the same signal level (around -60 dbm).
3. I tried playback of recorded RF signal (from freq 937Mhz) which is captured in the point 2. (playback .grc image is attached below).
Observation:
But we observe only noise from the playback using USRP. Noise is more when compared to data. Unable to recreate the recorded RF signals.
Do i need to change GNU Radio companion configuration? or calibrate USRP to get the spectrum for the configured Center freq as expected?
playback window
937Mhz playback grc file.
937Mhz record grc file
